wet passenger f;pprbpard
Old May 9, 2008 | 01:09 AM
akamario's Avatar
akamario
Default wet passenger f;pprbpard
My pasenger floor boardgets wet when it rains. It's not coolant, and ive tried a garden hose I just can find the leaking seals, anyone have any suggestions? It seems to be coming from somewhere up in the dash
Old May 9, 2008 | 02:17 PM
davmelrach's Avatar
davmelrach
Default RE: wet passenger f;pprbpard
Good luck! When you find out let me know 'cause mine has done it for a few years and I have never been able to find it.
Old May 9, 2008 | 04:14 PM
White Ram's Avatar
White Ram
Mine was leaking rain through the third brake light. New gasket +some RTV = dry interior.
Old May 9, 2008 | 08:52 PM
davmelrach's Avatar
davmelrach
On some trucks the light is the culprit, but on mine it wasn't. However I did have water coming in through there. You are correct about fixing that area if it has not been done. I certainly would try that first.
Old May 9, 2008 | 09:03 PM
Shawn86's Avatar
Shawn86
Yup mines gotten a little wet from time to time, at first I thought it was just coffee (my travel mug has a bad habbit of falling over into the passenger side) but nope its water!
But if the third brake late is the culprit, why is the front floorboard wet? Unless it goes through the roof, without leaking into the head liner; and down the pillar, without shorting out the tweeder, and then down onto the floorboard!
Old May 9, 2008 | 10:12 PM
dodgeram07's Avatar
dodgeram07
well.. i've had a water on my floors since the day i got the truck. i took out my interior three time and the last time i found it... the thrid brake light was part of it but the rest of it was the window(see pic)
after i seal it up it away been dry..
..Name:  prom08027-1.jpg
so basely there two place water can go in { on each side of the cab}.. almost like holes, so fill they up with something so water can get in and you guys should be dry like me.lol ....hope this help...... sory the pics are big not to good with his computer stuff
Old May 9, 2008 | 10:24 PM
aim4squirrels's Avatar
aim4squirrels
I had a problem with my driver's side leaking because the door wouldn't close properly on the outer weather seal. While in the bed of the truck check the side that isn't leaking carefully and pay attention to where you see the gaps in the top of the doors and the seal. then go to the other side and check the seal there and see if you notice any differences.
Another common problem is for the AC evap canister drain tube on the passenger side firewall to plug up with a sort of slimy gunk and the water will run into cab on the passenger side floor board and soak the carpet. You can usually unplug it by running a coat hanger up it and unclog the tube. If it is the slime problem, it will probably come back, but you can try to get rid of it permanently with a type of enzyme cleaner that they use in the catch trays of window air conditioning units.
