The Money I Save at 55.
ORIGINAL: padodgeram
It blows my mind that people get worse MPG stock then i do with mine . OT , on the local news the did a flash back when gas was 1.32 a gal . then people where saying the same as people do now .. to get every mpg out of the truck , tires , change fluids , electric fans , pullies , gears , exhaust , even if i went out and bought a better road tire still using the 35s size i mite gain 2 mpg back instead using the mud tire... keep your ride waxed will help to slip thru the air and yes you can even wax the windshield , works good in the rain to... And of course your driving habbit , Ask my wife about her driving habbit , LOL , That why im replacing brakes every 3 months and oil change every month( job requires driving) .
ORIGINAL: 1BigRamaniac
At long lights I shift into neutral. I keep 40psi in the tires.
wind resistance or not, my truck gets its best mileage at 72 mph. at 55-65, it feels as if the engine is using more fuel to keep itself moving. at 72 mph, i can get about 18 mpg depending on terrain. on long trips, draft a semi. believe it or not, i have gotten over 20 mpg this way. I can make my frequent drive to San Jose, CA from San Diego, CA on a tank of gas. figure that one out.
I wasn't quite there, but I remember learning some new words from the old man over that mess while sitting in line. Hopefully, opec will continue to love money more than they hate ****.
ORIGINAL: dodgeforlife15
Just curious why you shift into neutral at long lights. I tried this out and it didn't affect my RPMs. Also, I thought having the specified tire pressure in your tires would give you the better mpg's, thought lowering it was for comfort purposes.
Some of the hypermiling things are not forme like drafting off of a truck. This is mainly because I don't like rocks and chipped paint. Watch a truck the next time it rains. It looks like a lot of wind is coming out under the truck.
From the article:
Every 10 mph faster reduces fuel economy by about 4 mpg, a figure that remains fairly constant regardless of vehicle size, Clark said. (It might seem that a larger vehicle, with more aerodynamic drag, would see more of an impact. But larger vehicles also tend to have larger, more powerful engines that can more easily cope with the added load.)
So if I'm getting 17 at 70, I'm going to get 21 at 60. I'm a little skeptical. I wonder if "low pressure hole" applies to p/u's with no tunneau (sp.) or cap.
speed will kill mileage... like others have said each truck/car will have it's sweet spot, you just have to find it. I believe it's tied to the torque peak... when doing this testing https://dodgeforum.com/m_1037052/tm.htm I'd experimented with several different setups and was able to see which setup gave me more low end torque, ultimately turning up the power on the truck and driving the same gave me the best mileage at 18.8 mpg... the all time best on my truck was 19.0 so I was not too far off of that, and the power settings were different then as well.
someone made a reference to getting a rice burner for fuel savings... well i have another option which you'll probably like better... VW 1.8t equipped (golf, jetta, passat, audi a4)... there are a ton of upgrade go fast goodies for that motor and it's pretty bullet proof from what I can tell. 200+ whp (modded of course) and 28+ mpg when you need it... I have a 2001 jetta for commuting (still 170 mi/day) and in doing so I managed to save over $1100 bux in fuel in the 8 weeks that I've owned it.
and yes I have the data to show for it...
