engine light code number
Old Jan 12, 2005 | 08:19 PM
countryboy's Avatar
countryboy
Default engine light code number
My engine light came on so i used the on/off method to find out what them number was, and 1740 is what came up. Does anyone know what this means?
Old Jan 13, 2005 | 02:42 AM
Ramtuff's Avatar
Ramtuff
Default RE: engine light code number
I don't have that code listed in any of my manuals, but you shouldn't be getting a four digit code with the key trick anyway. It will flash two digit codes. Also, any codes that you get using that method won't end in a zero.
Old Jan 13, 2005 | 01:26 PM
CANADIAN RAM01's Avatar
CANADIAN RAM01
1740 Either the tcc solenoid or overdrive solenoid systems doesn't seem to be making much sense.
http://www.allpar.com/fix/codes.html
