Clicking Noise and Leaking front differential by axel
Old May 10, 2008 | 09:51 AM
shockwave's Avatar
shockwave
Default Clicking Noise and Leaking front differential by axel
So I week ago I noticed that my front driver sidetire clicks once every revolution. Gets pretty annoying. Also there is front differential fluid leaking out that driver side axel assembly. I took of the tire and the noise is coming from inside that assembly when the tire is rotated. Any ideas?
Thanks
Old May 10, 2008 | 10:03 AM
triplethreat's Avatar
triplethreat
Default RE: Clicking Noise and Leaking front differential by axel
Not sure about the clicking, but your seals have gone bad in the axle shaft. I replaced mine last year. The good news is the seals are not expensive, the bad news is it is a bit of work to replace them.
Old May 10, 2008 | 10:25 AM
timsalas's Avatar
timsalas
U know I had something similar to this.. turned out to be a nail stuck in the tire..
Old May 10, 2008 | 11:04 AM
TheForce55555's Avatar
TheForce55555
Its most likely that the U-Joint is shot on the driver's side and the axle seal is leaking, the parts are cheap, but you have to pull the front differential out to replace them.
