Output Speed Sensor Location
Old Sep 28, 2012 | 02:16 AM
  #51
ReadRam's Avatar
ReadRam
Originally Posted by ElyRam
1999 Ram 5.2L 4x4 here, 140K miles. Just got a p0720 code and did a Google search and found this forum.
I've done most of my own light/medium mechanic work for 30 years, but this truck is new to me. Looks pretty simple to replace the output speedometer sensor.
But I have a couple questions. First, a couple symptoms. When I accelerate, my inside vents kick over to defrost, and when I take my foot off the gas, there's a slight popping sound (single pop) and the vents kick in again. Also, just after it threw the p0720 code, when in cruise it will occasionally bump up about 200 rpms for a second and then come back down to cruising speed. Sometimes it does this two or three times.
BTW, fluid and filter were fresh last year, about 10,000 miles ago. I have ABS but the ABS light is not on. No other lights are on, and p0720 is the only code being thrown.
So:
1. Is the p0720 code always the output speedometer sensor?
2. Would a faulty sensor be causing the goofy switch between vents and defrost upon acceleration?
3. Do I expect to lose some tranny fluid when I pull the old sensor?
Thanks for any help.
I got that code also, but it was the TPS that was causing the 200 rpm jump, worse when I used cruise. TPS=throttle position sensor.
check valves,two of them from dealer,will cure vents switching. And yes you will get some tranny fluid on you doing output speed sensor, go fast with some cardboard down.
Old Sep 28, 2012 | 06:24 AM
  #52
rwspellman78's Avatar
rwspellman78
Thumbs up Output speed sensor
The last one i changed on my 06 was right on top of the rear-end just follow the wires
Old Sep 28, 2012 | 09:09 AM
  #53
DallasOregon's Avatar
DallasOregon
I just went to Dodge yesterday. Guess where he said it was on the '98? The front, drivers side, on the transmission. The thing I am seeing on the rear end does not match the part they state is the speed sensor.
Old Sep 28, 2012 | 09:25 AM
  #54
rwspellman78
i just googled it and it showed a pic of the tranny cable on drivers side rear middle right before the cone and runs ti top middle of tranny and plugs into mtr etc....on google i typed PO720 output speed sensor location it was like the 3rd one dwn
Old Sep 28, 2012 | 09:27 AM
  #55
rwspellman78
sorry about post earlier thought u were talking about 99 ram
Old Jun 10, 2013 | 10:18 AM
  #56
campdavid_al's Avatar
campdavid_al
hello. I also have a 1999 dodge 318 5.2 engine, a transmission whith overdrive, and my check engine light is on, the code says that it is my output circuit speed sensor, and i would like to no what it is and where it is? and if anyone Knows the cost and how hard it is to repair? thank you
Old Jun 10, 2013 | 10:30 AM
  #57
campdavid_al
how do you no which sensor is the one that is bad, if there is two of them? on the 1999 dodge 318 5.2 2 wheel drive with auto trans, overdrive trans.
Old Jun 10, 2013 | 10:34 AM
  #58
Nereaga's Avatar
Nereaga
Does your cruise control work? If not, that's the sensor on rear axle housing. If tranny is shifting at bad points, will be the sensor on trans.
