Yet another cooling system question...
Old Jan 15, 2005 | 02:51 AM
Snafu's Avatar
Snafu
Default RE: Yet another cooling system question...
Theoretically no, they can't compensate for it. A former buddy of mine runs a Jet Stage II chip with no thermostat. The truck has tons of power, but his rings are SHOT. The Jet chips also usually put slightly more fuel in the mixture for more power. Fuel actually works as a coolant in the combustion chamber, so the more you have the cooler the engine runs. This complicates the problem of the lower temp thermostat. I really think that it's hit or miss with the chips because the fuel injection systems are pretty well optomized from the factory. Only way to make major differences reliably will be from larger injectors and higher flow throttle body combined with programming changes.
Old Jan 15, 2005 | 02:54 AM
Scootr's Avatar
Scootr
Thank you for breaking that down for me Snafu!
Old Jan 16, 2005 | 12:47 AM
carshemi's Avatar
carshemi
Snafu not to argue but if your buddy has tons of power then how can his rings be shot? I could see that being caused by No thermo. You can have more chance of over heating with-out a thermo. The coolant has no chance to cool down in the rad! But if the rings are shot then were's all the blow by going, what's the compression reading.You don't make TONS of power with bad rings. Sorry just curiuos?[sm=dontgetit.gif]
Old Jan 18, 2005 | 05:02 PM
MOGAMAN's Avatar
MOGAMAN
I JUST BOUGHT A USED 99 5.2 RAM AND SAW MY TEMPS AT LIKE 180-170 RANGE FIRM. I DIDNT THINK IT WAS NORMAL. I ASKED THE PREVIOUS OWNER AND HE SAID HE DID NOT INSTALL A LOWER TEMP THERMASTAT. COULD MY STOCK ONE BE STUCK OPEN? MAYBE SOMEONE DRILLED HOLES IN IT? WILL THE OPTIMUM RUNNING TEMP GIVE ME BETTER GAS MILEAGE? I SHOULD CHECK IT OUT.
Old Jan 18, 2005 | 05:03 PM
MOGAMAN's Avatar
MOGAMAN
SORRY TO THREAD JACK
Old Jan 18, 2005 | 11:09 PM
carshemi's Avatar
carshemi
If fluid level isn't low could be several things. Stat could be bad, could be stuck?The easiest check. Pull the stat. Change it 15 mins. tops.Maybe 8/9$ it's a little tight but not bad. Clamp the hose and save from dumpin' coolant every where. Don't drop the bolts in the stat hole!BTW 180* stat has NO effect on P.C.M.,Throttle body,etc. The P.C.M. stays in open loop mode for the best fuel/air mixture until the o2 sensor reaches operating temp. 600*F. Then reads the o2 from there out.Dout anyone drilled it but you never know?[sm=usa.gif](have had them in both my trucks)
Old Jan 19, 2005 | 11:56 AM
MOGAMAN's Avatar
MOGAMAN
THANK YOU SIR.
Old Jan 19, 2005 | 09:33 PM
carshemi's Avatar
carshemi
Not a problem! Post after you get it checked-out? Didn't get how many miles on it?Good luck[sm=smiley20.gif] Hope that's all it is any easy fix?
Old Jan 20, 2005 | 11:40 AM
doziersdodge's Avatar
doziersdodge
Go with the 180 thermo. That is what I have in mine. Had it for several years...no problems. I had a leak in my timing cover gasket several years ago. Got the kit and changed the gasket, hoses, water pump, thermo., etc., etc. My temp. was up and down...I was also losing coolant but no puddling. Took me a day to do it, right. Spent less than $100 for extra reassurance.
