Installing new motor for power window 95 Ram
Old May 14, 2008 | 11:36 AM
finfan73's Avatar
finfan73
Default Installing new motor for power window 95 Ram
Has any ever had to change the motor for their power windows? Mine went out last night and I am trying to find some instructions on how to change it. Thanks.
Old May 14, 2008 | 05:29 PM
motorbrreath's Avatar
motorbrreath
Default RE: Installing new motor for power window 95 Ram
very easy. pull the door panel off, youll see the motor once you pull it off. its 3 hex screws and it pulls right out. put the new one in with a little grease on the teeth, and screw it back in and your good to go.
Old May 14, 2008 | 06:09 PM
Mudbone25's Avatar
Mudbone25
Might want to get a door panel puller from a parts store so you dont break the plastic retainers.
Old May 20, 2008 | 03:32 PM
finfan73's Avatar
finfan73
Thanks for the info. Was able to get it in there without any trouble. Wish I had seen the other post though as I did break some of the little plastic clips but those were cheap and easy to replace. Thanks again!
