NO BUS
Old May 23, 2008 | 01:03 PM
telekellen's Avatar
telekellen
Default NO BUS
Hi All.
Was hoping to gleen some info about what exactly is going on with my truck.
First off, 2001 Dodge Ram, Cummins, 4x4 Reg. Cab.
Was pulling in the driveway this afternoon and all the idiot lights came on, all the analog gauges went dead, and NO BUS read in the odometer. The truck ran fine, and I've started it twice since then, but same symptoms occur. So, truck runs and starts fine (or, at least normal from what I can tell).
Haven't scanned for codes yet. Try and get that done tomorrow. Anyway simple first steps that I could try? Loose connections?
Thanks!
Old May 23, 2008 | 07:43 PM
Dodgeman000's Avatar
Dodgeman000
Default RE: NO BUS
It might be a fuse. I couldnt tell you which one to check though.
Old May 24, 2008 | 06:44 PM
telekellen's Avatar
telekellen
Default RE: NO BUS
Just to update, I fixed the dead gauges and "No Bus" in the odometer by listening to another Dodge Forums member who pulled the "Inline Engine" plug in the junction box and cleaned it with contact cleaner. Gauges are back on-line and no codes are popping up.
Sweet!
