speaker depth
Old May 25, 2008 | 02:55 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default speaker depth
Just currious what is the maximum speaker deapth for the front doors? I want to upgrade but the new Infinity kappa 6.5 components have a huge magnent.
Old May 26, 2008 | 12:07 AM
dhvaughan's Avatar
dhvaughan
Default RE: speaker depth
i'd say 2 7/8 without any shimming. but you can easily shim out about 1/4 inch which gets you to about 3 3/8. be careful, you have to watch both your depth and your tweeter height. what i did was pick out the speaker i thought i wanted and got its dimensions. then pulled off the door panel and made a mock up with those dimensions to see if it would fit. careful about pioneers, the tweeters on some models stick out a lot.
https://dodgeforum.com/m_773176/tm.htm
Old May 26, 2008 | 02:00 AM
Zeppelinrocks
Thanks so much for the answer and they will fit they are 2 3/16 deep.
