tcc solenoid/ od solenoid helpppppppp
Old May 26, 2008 | 07:42 PM
Shawn86's Avatar
Shawn86
Default tcc solenoid/ od solenoid helpppppppp
I thought I'd already posted this but I can't find it now!
I need to replace the tcc solenoid/ od solenoid but heres my question before I go to the stealership. Is it an all in one solenoid, "solenoid pack", or are they individual. One of the shops up here that I've been talking to has mentioned a solenoid pack but i'm not sure what that is exactly. Also on RockAuto.com I found this:
STANDARD MOTOR PRODUCTS Part # TCS51 {TRANSMISSION CONTROL SOLENOID}
4 Speed Transmission; With Lock Up Converter
[/align]
$88.79
$0.00
$88.79
Is this the "solenoid pack" that they're talking about and is it what I need?
Thanks in advance,
Shawn
Old May 27, 2008 | 09:49 PM
Shawn86's Avatar
Shawn86
Default RE: tcc solenoid/ od solenoid helpppppppp
Ok, does anybody have any input? I really need to get these parts this week cause I'm going on a road trip in a few weeks and I kinda don't wanna do it on a fussy tranny!
And I really don't want to have to get them at the stealership.
Anyone, anyone............... Bueler, Bueler!
Old May 27, 2008 | 09:56 PM
eflores's Avatar
eflores
so far as i have can tell having purchased quite a few for the shop they all have to come from the steelership and i personally have never seen a pack with all the solenoids im sure it would be several hundred is there were such a thing
Old May 27, 2008 | 10:05 PM
dsertdog56's Avatar
dsertdog56
Your OD/Lockup selenoids are on the same bracket and are replaced together. While you have things that far apart, you might as well replace the shift selenoid and pressure switch too, since they both get plugged with the same guck that screws up the tcc selenoid.
Did you throw a code? Based on experience, you are probably putting a band-aid on a cracked bone. Good luck.
Old May 27, 2008 | 10:19 PM
Shawn86's Avatar
Shawn86
Yeah it threw a 1740 code and I've been hassling with it for almost a year now! It has a good strong shift, its just fussy and a little hesitant.
