Band adjustment
Old May 27, 2008 | 11:00 PM
lizardhunt's Avatar
lizardhunt
Default RE: Band adjustment
I hae to admit that will definatelybreak something loose.
I'll try that one next time I have a little more cash to drop into repairs and more time than I know what to do with.
Old May 28, 2008 | 12:30 AM
eflores's Avatar
eflores
mine is a 99 4x4 auto with a 318 and 3.55 gears. when power breaking it, it wont break one lose nor will it push. i just dropped the motor in on saturday. just a fresh 318 with some pretty shaved heads. maybe this truck is just gutless for its size, i just want it to drag my crawler to moab and back
Old May 28, 2008 | 07:50 AM
aim4squirrels's Avatar
aim4squirrels
Have you checked for a clogged Catalytic Converter or a Blown Plenum gasket? Both could rob you of a good deal of power.
Old May 28, 2008 | 08:05 AM
eflores's Avatar
eflores
clogged cat is a possibility they guy i bought it from cut the muffler off and to tell you the truth with just a cat and hunk of pipe its not that loud.....my 4.0 in my jeep is louder
Old May 28, 2008 | 08:06 AM
eflores's Avatar
eflores
oh and my plenum is fresh...
Old Jun 28, 2008 | 07:34 PM
RICKSOCAL's Avatar
RICKSOCAL
I know i am going to get quite the load of sh** for re-posting.... this was posted in an older post and i thought i should've done it in the newest post this one. so here is my question:
the rear band adjustment.... where the hell do u get the square socket for the adjusting screw to tighten it to 72 in lbs?
i went to three different stores and none sold it and all had puzzled looks on there faces.
so to make sure what i am doing is right....
loosen the lock nut, and back it out 5 turns . 5 complete 360 turns, right? then tighten the adjsuting screw to 72 in lbs? then tighten the lock nut back up to 25 or 30 ft lbs?
i have a 46re tranny on a 5.9 2001 2wd 97,000 og miles on everything. just swapped out the alternator and that's about it. 1 previous owner b4 and he pampered it, i have pampered it, but now i must makee some routine maintanace on it. axle bearings, seals, diff. oil, u-joints(frnt & back single shaft), rear brakes, turn drums, tranny drain and band adjustment.
i need help in figuring were to get that freakin tool.
i am lost in translating the different specs out there. the haynes manual says 3 turns other people are saying 4 turns then there is the 2 7/8 turns, what the hell?
