Ram Magnum V6 Distributor access
Old May 27, 2008 | 06:16 PM
MIKEINNV's Avatar
MIKEINNV
Default Ram Magnum V6 Distributor access
Any one who has attempted to access the distributor of 95 or newer Ram Pickup knows how tuff it is to get to. Any one have a trick ? Can the upper plastic molding be removed ?
Old May 27, 2008 | 06:25 PM
padodgeram's Avatar
padodgeram
Default RE: Ram Magnum V6 Distributor access
ORIGINAL: MIKEINNV
Take off the air cleaner , its not easy but not hard either , your gonna lay across the motor so make sure its cool , use a philps screwdriver and be careful not to break the bolts ,
Old May 27, 2008 | 07:39 PM
wvjefo's Avatar
wvjefo
+1 take off the air cleaner, then get a step ladder. Not hard to do just hard to reach. Climb right inside that engine bay. Get the Manual. Very easy to srcew up the plug wires.
Jeff
Old May 27, 2008 | 07:49 PM
aim4squirrels's Avatar
aim4squirrels
Hold your kid by the ankles over the engine bay and hand him a phillips head screwdriver. I find that 9-10 year olds are the best. Smart enough to do the job, skinny enough to hold for a few minutes, and small enough hands to fit back there.
Old May 27, 2008 | 08:03 PM
padodgeram's Avatar
padodgeram
ORIGINAL: aim4squirrels
Sit back with a beer for a job well done , OPPPPSSSS gotta be PC , sit with a bowl of icecream for a job well done...
Old May 27, 2008 | 08:08 PM
jasonw's Avatar
jasonw
Site Moderator
I used different colored cable ties to label the wires and which posts they go to. Replaced one wire at a time once the cap and rotor were replaced, so that I could follow the exact routing of the old ones. Worked very well. Luckily for me, I have long, skinny arms.
Old May 28, 2008 | 10:11 AM
MIKEINNV's Avatar
MIKEINNV
That's what I did !! I have a step that attaches to the front wheel for easy access that way, but had to remove the cap by feel and a small phillips. But I was thinking that if I have to replace the plug wires or pick-up coil, things are gonna get nasty !! I was just thinking that there has got to be a better way !! LOL Thank you Dodge, for placing that between the engine and the fire wall. What where they thinking ? Oh ya, bring it to us if ya want it worked on. LOL
