confused please help
Old Jun 1, 2008 | 11:11 PM
methpmp's Avatar
methpmp
Default confused please help
i am confused, yesterday i replaced the plenum gasket along with the intake manifold gaskets and i still have the same vacuum leak that i cant find, when i get on it, my vents goto defrost and it sounds like ****
i have checked all the lines and the check valves and i dont know what else to look for any suggestions
Old Jun 1, 2008 | 11:36 PM
charlie1935's Avatar
charlie1935
Default RE: confused please help
If you have cruise control che the lines to it under the battery if you haven't.
Old Jun 2, 2008 | 07:01 AM
dhvaughan's Avatar
dhvaughan
there is also a vacuum cannister underneath the plastic cowl thing.
you might need a hand operated vac pump with a gauge. it lets you test individual lines. about $15-20 at cheap places like harbor freight.
there are 2 of those check valves. forget testing, i'd replace them both.
