402 stroker,real pig.
Old Jun 6, 2008 | 09:22 PM
spaksauto's Avatar
spaksauto
Default 402 stroker,real pig.
need help on new 402 stroker install. In a 97 1500 4x4.Stock injectors and throttlebody.No ecu upgrades yet.Can't get out of it's own way.
Old Jun 7, 2008 | 07:03 AM
charlie1935's Avatar
charlie1935
Default RE: 402 stroker,real pig.
I think you stated the reason in your sentence about the stock components you're running.[sm=americanasmiley.gif]
Old Jun 7, 2008 | 09:20 AM
RM_Indy's Avatar
RM_Indy
Is that the Mopar 402 crate?
If yes, you will need 55mm tb (Hughes or F&B), 30lb injectors (bigger w/power adders) and an SCT tuner (hemifever @ Dodge Talk dot com sells/tunes them)
Besides the above, did you set the fuel sync? If the distributor is off a couple degrees that will also suck a lot of power from the motor cause of the injectors firing out of time from the valves.
Old Jun 7, 2008 | 09:43 AM
spaksauto's Avatar
spaksauto
yes it is a mopar crate motor.Rm Indy,if your out there,could you call me collect at 215 295-4731.Everytime i write something,it boots me off.Thanks,Ed.
Old Jun 7, 2008 | 09:46 AM
RM_Indy's Avatar
RM_Indy
short replies seem to work, what do you need to know?
Old Jun 7, 2008 | 09:51 AM
spaksauto's Avatar
spaksauto
Cam sync is at 1,will adjust to 0?Smaller cam,214&224 at .050,lobe sep at 114.How to tune
Old Jun 7, 2008 | 09:54 AM
RM_Indy's Avatar
RM_Indy
should be good at +1, I usually go for 0 to +1
hemifever will give you a good tune if you give him all the specs on what u have
