Fan clutch pulley removal
Old Jun 14, 2008 | 11:16 AM
Obiejuankinobie's Avatar
Obiejuankinobie
Default Fan clutch pulley removal
I cant get the fan clutch off. The four bolts behind the fan are removed but the clutch is still in there. There is a hex spacer behind the clutch. Does this hafta come off? Taking a break will check later.
Thanx
Old Jun 14, 2008 | 11:53 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: Fan clutch pulley removal
The hex thing you see is a 36mm nut that holds the clutch to the water pump pulley.
Old Jun 14, 2008 | 12:03 PM
zman17's Avatar
zman17
Put the 4 bolts back in so you can use a bar or a large screwdriver between 2 of the bolts to keep it from turning while you use a large enough wrench or special fan tool to loosen the nut.
Old Jun 14, 2008 | 12:43 PM
aim4squirrels's Avatar
aim4squirrels
Put a Strap Wrench on the WP pulley and a 12" or larger cresent wrench on the fan clutch nut.
aim4squirrels
Shoot it down with PB blaster and give her hell.
