A/C compresor clutch signal
Old Jun 19, 2008 | 08:48 AM
thewrench's Avatar
thewrench
Default A/C compresor clutch signal
I have a00' 2500 5.9
A/C doesn't blow cold, clutch doesn't lock up when running. perf evac & recharge of system. didn't find any leaks, it' held agood vac for 15min beforecharging.Once it's charged,still no clutch lockup.Checked the connector to the compressor, no voltage comming in. Jumped 12v& ground to the comp and the clutch locks up anda/c blows cold. So....
Where does the compget it's signal from? Hi pres sensor? Low pres sensor? I'm thinking I should just be able to removed a sensor connector and jump the pins,do this to both hi & low, and see
which one,when jumped, turns the comp clutch on?
Should work in my head, but I dont' have much experiance w/ domestic's, i'm a euro car tech by trade.
-Wrench
Old Jun 19, 2008 | 03:48 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: A/C compresor clutch signal
the low side clutch resistor is on the drier canister by the PCM. Not sure where the high side one is.
Old Jun 19, 2008 | 04:10 PM
thewrench's Avatar
thewrench
Yeah, the high side is right off the pres line near the compressor. I just need to know where the signal comes from. I don't wanna be jumpin pins and powering something that does get power, or is maybe ground switch...
Anyone?
-Wrench
Old Jun 20, 2008 | 01:43 AM
tom01973's Avatar
tom01973
jump the switch on the accumulator and see if compressor turns on.if it does then switch is bad.do the same with the high side switch by the compressor
