IAC questions
Old Jun 23, 2008 | 09:04 PM
hometheaterman's Avatar
hometheaterman
Default IAC questions
Since I can't post much again go here is a link to my question. http://pavementsucks.com/forums/view...p?topic=123881
Old Jun 23, 2008 | 10:00 PM
pcfixerpro's Avatar
pcfixerpro
Default RE: IAC questions
As far as I know, the IAC is only for idle. At WOT, its not used? In which case wouldn't cause a loss of power. Just thinking out loud
Old Jun 23, 2008 | 10:04 PM
hometheaterman
Thanks. Can't post much it wont let me. I guess the long posts are gone again.
Old Jun 23, 2008 | 10:11 PM
kowboydmac's Avatar
kowboydmac
i changed mine when i did my o2 sensor swap. smoothed things out, but really couldnt tell ya what the IAC affected, as it was mostly the o2 being burnt up.
Old Jun 23, 2008 | 10:22 PM
Timb75's Avatar
Timb75
Well it does open up completely at WOT. It may restrict a little if the port is blocked but not enough to really matter. Still it may be a good idea to give it a good cleaning before it does fail. Mine never really failed. It broke. The port my IAC moves in wasso gummed up with carbon it broke the rod off of the IAC motor. The best IAC around is the stock IAC. After market ones are known to cause a lot of problems. Keep this in mind.
