a/c clutch bearing
Old Jun 27, 2008 | 05:53 PM
cmares's Avatar
cmares
Default a/c clutch bearing
Does anyone know where I can get a new a/c clutch bearing for 2001 ram 5.2 L.
Old Jun 27, 2008 | 06:20 PM
matt7591's Avatar
matt7591
Default RE: a/c clutch bearing
Been there done that. Just replace the whole unit. Suspect only from the factory but they still have to inspect the compressor seals after taking off the clutch.
Old Jun 28, 2008 | 03:35 PM
Gwub2005's Avatar
Gwub2005
i was told u can't replace just the bearings but the whole compressor unit will have to be replaced
Old Jun 28, 2008 | 04:12 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Don't waste your time , replace the unit.
Old Jun 28, 2008 | 06:52 PM
rabbler's Avatar
rabbler
The Clutch assy should be available separately.
If you remove the clutch pulley you can probably get a bearing supply store to match it up. The bearing should have some id numbers stamped on it.
You don't have to discharge they system to remove the clutch assy.
