Lift Kit ??
Old Jul 3, 2008 | 01:14 AM
RamMan_8520's Avatar
RamMan_8520
Default Lift Kit ??
I am lookin to lift my truck about 3 to 3.5 inches. what are some good lifts to go with and have any of u done this and what should i look for. Thanks
Old Jul 3, 2008 | 09:23 AM
ct.russ's Avatar
ct.russ
Default RE: Lift Kit ??
I WENT TO TRUCK CUSTOMZ AND GOT THEIR 3 INCH LEVEL KIT .. ONLY PART I DIDNT LIKE WAS THE ADDED 1.5 INCH BLOCK FOR THE REAR .. I WAS TOLD 3 INCH IS MAX WITH THE STOCK ARMS IN THE FRONT.. ITS A STRIGHT FORWARD INSTALL .. I DIDNT FOLOW THE DIRECTIONS TO A "t" .. SO I DIDNT HAVE TO GET A NEW FRONT END ALLIGMENT .. IF YOU DISCONNECT THE SWAY BAR YOU HAVE ENOUGH ROOM TO PUT THE SPRING BACK IN .. RUSS
Old Jul 3, 2008 | 11:24 AM
globalwarmer01's Avatar
globalwarmer01
You can get a 3in. Front / 2.5. Rear lift from Pro Comp for 490.95 from 4wheelparts.com. I order all my stuff for my ranger from them.
[*]Stage I[*]Recommended tire size= 33 x 12.5[*]Front Coil Spacers[*]Rear Add-a-Leaf[*]Rear Block w/ U-bolt Kit[*]Front / Rear ES3000 Shocks[/ul]
Old Jul 3, 2008 | 12:56 PM
hometheaterman's Avatar
hometheaterman
4wheelparts.com has a bad reputation. I'd check out 4wheelcustoms.com instead. I have a 3" Skyjacker lift and like it but honestly you could get a spacer and AAL for cheaper and just do that. I'd get something with a AAL for the rear instead of a block if it was me.
Old Jul 3, 2008 | 03:18 PM
globalwarmer01
How did 4wheelparts get a bad rep? I've been buying parts from them for 4 years and i've never had a problem. I've had 5 trucks and i bought parts for all of them and never had a complaint. It all depends on if you go muddin or do some serious wheeling. You can go many places with just a spacer and AAL. A block lift in the back is a great setup for a add a leaf for serious crawling.
Old Jul 3, 2008 | 03:34 PM
hometheaterman
For messing up orders is the biggest thing I've read about and just being hard to deal with. Go on over to Pavementsucks.com and read about them. You can see they have quite a few unhappy customers. I personally might order from them as they don't seem to just flat out rip you off but seem to not be the best when there are other companys with better service.
Old Jul 3, 2008 | 05:02 PM
ct.russ's Avatar
ct.russ
u can get just the spacers like a hunderd i think .. but you will need a longer shock in the front .. i agree fully i dont like the added rear block and will get an aal .. my kit came complete spacer, block , u bolts and 2 shocks with boots , and two t shirts shipped for 260 ish when done youll sit just as high as a stock 2500 .. another ave would be to put in the 2500 springs and an aal out back .. not shure what the price difference is
hope ive helped
russ
