My Cardomain Page
Old Jul 8, 2008 | 11:10 PM
hometheaterman's Avatar
hometheaterman
Default My Cardomain Page
http://www.cardomain.com/ride/3114344
Leave some comments. I thought I had one before but for some reason it wasn't showing up so I created a new one.
BTW anyone know how to get a background color? I tried doing html code and that doesn't seem to work. The code doesn't show up in the page but neither does the color. What do I need to do on there for a background?
Old Jul 9, 2008 | 01:05 AM
hometheaterman
Default RE: My Cardomain Page
bump. Anyone know how to do the background colors since html doesn't seem to work?
Old Jul 9, 2008 | 10:30 AM
RM_Indy's Avatar
RM_Indy
Looks good Homey [8D]
As far as backgrounds go there,,,,,,,
Click edit page, then look at the left hand sidebar area where it lists "vehicle info". Half way down is background. You can add a color thereor"browse" to uploada picture to use asthe background. If you want something like I have on my page or my .com website(tiled)just reduce the size of the picture. Best not to use a picture that is too busy (can reduce opacity so its more subtle) or it distracts from you page.
Put 2 versions ofaMopar logoat the bottom ofmy lastpage at CD that you can try/use if you like Have to click on the "expand picture" though to get the smaller version. (odd)
http://www.cardomain.com/ride/2363984/5
Old Jul 10, 2008 | 07:46 PM
hometheaterman
Thanks not sure how I skipped over that. I got it changed.
Old Jul 10, 2008 | 08:36 PM
dodgeram07's Avatar
dodgeram07
what kind are those front speaks?
Old Jul 10, 2008 | 10:15 PM
hometheaterman
Speakers? If so they are Polk DB Components. I got them around Christmas time of 07 from Crutchfield. So not sure if they are still the current model or not. The rears are Polk DB Coaxials I'd had for a little while before I got the component set. I just mounted the tweeters over the speaker in the front thats why the tweeter is there. You can mount them most anywhere you want.
Old Jul 11, 2008 | 12:33 PM
dodgeram07's Avatar
dodgeram07
did they work with the infinity sound system?
Old Jul 11, 2008 | 12:37 PM
hometheaterman
They don't use any components of the factory sound system. The need a amp to power them. Basically the only stock part of my system still in use is the wiring harness to the h/u that gives it power. I have new speaker wire run from the amp to the Polk DB components in the front and the amp is connected to the h/u with the preamp outs so basically it's just bypassing the factory setup.
Old Jul 11, 2008 | 01:29 PM
dodgeram07's Avatar
dodgeram07
thank you.
