Power window switch
Old Jul 11, 2008 | 02:13 PM
V10 Jim's Avatar
V10 Jim
Default Power window switch
Need to know if you can "pop" the power window switch cluster out of the driver side door panel with-out damaging it, or do I need to remove the door panel to get at it. The switch for the pass. side winow is not working properly and I want to fix it
Old Jul 11, 2008 | 02:27 PM
hometheaterman's Avatar
hometheaterman
Default RE: Power window switch
I'm guessing you are going to have to remove the panel but I'm not 100% sure on that.
Old Jul 11, 2008 | 03:12 PM
engineblock's Avatar
engineblock
you could pop it out
Old Jul 11, 2008 | 10:46 PM
V10 Jim's Avatar
V10 Jim
Thanks for the replies. You can access the switch assy. w/o taking off the door panel. You can "gently" pry up the switch cover and remove the entire switch assy. FYI you can dis-assemble the switches and clean the contacts. The switch works like new again. Thanks all[sm=americanasmiley.gif]
