abs/brake light and speedo
Old Jul 11, 2008 | 05:38 PM
b1pw3ha's Avatar
b1pw3ha
Default abs/brake light and speedo
Hey all, I have a 99 ram 360. Yesterday while driving my abs/brake lights came on. My brakes are fine my parking brake is no engaged and now I dont have a speedometer.
Can anyone help me out and point me in the right direction on what can be causing this? Is it some sort of sensor?
Thanks in advance to all who reply
Old Jul 11, 2008 | 06:48 PM
greenmachine's Avatar
greenmachine
Default RE: abs/brake light and speedo
I know the 99 has the speed sensoronthe tailshaft of the transmission on the drivers side (believe that is the last year in that position). These trucks also only have rear ABS that sensor is on the top of the diff. Odd that both those things happened at the same time. Speed sensor is just a magnetic pick up may be covered in sludge. Clean it first, have a rag ready to stuff the hole, then try the speedo again. Still dont work replace-cheap part.
Old Jul 11, 2008 | 07:41 PM
SarcasticDwarf's Avatar
SarcasticDwarf
Care to explain why a rag is needed? I had the same thing happen with my 98 last week.
Old Jul 11, 2008 | 10:11 PM
aliasmax's Avatar
aliasmax
Hi, The symptoms you are describing are most likly the abs sensor on top of the rear dif. did you go through deep water or mud recently? On another dodge forum this was brought up alot. It was suggested to unplug the sensor and clean up both ends. When mine did it when i cleaned it up and it went away.
Old Jul 11, 2008 | 10:18 PM
zman17's Avatar
zman17
Retired Moderator - RIP
" Care to explain why a rag is needed?" Uhhh , so no tranny fluid leaks out and makes a mess would be my guess.
Old Jul 12, 2008 | 03:27 AM
greenmachine
ORIGINAL: zman17
True my friend very true
Old Jul 12, 2008 | 12:19 PM
b1pw3ha's Avatar
b1pw3ha
Nope, truck has never been 4 wheeling or through deep water. I did however have it in a field of high grass the day the lights all went on.
I guess I can start with changing the rear abs sensor then work to the sensor on tranny.
Thanks for everyones help
Old Jul 12, 2008 | 07:40 PM
aliasmax's Avatar
aliasmax
If i remember correctly the sensor is about $60.00. Before you buy one try unpluging the wires and cleanup both ends.
Old Jul 12, 2008 | 09:00 PM
robinbobin's Avatar
robinbobin
if cleaning both ends dont work take it out and look at it...my bro inlaw had a 3rd gen ram that haf the same problem, so i tried cleaning the connectors no luck, took the component of the diff case, and what do you know the piece was totally hammered all broken up and such hope this helps
