differences between 95 and 99 5.9
Old Jul 12, 2008 | 10:04 PM
snoop1's Avatar
snoop1
Default differences between 95 and 99 5.9
I've started working on putting a 5.9 into my 3.9 92 Dakota.
I picked up an engine today and was told I was getting a 95 motor (which is what I asked for). But when I got home and looked at the tag that was put on it when it was pulled the motor came from a 99.
So I'm looking at the electrical connections and vacuum ports on the 3.9 and comparing them to the 5.9. There are less vacuum ports and one less sensor (temp?, a little one right behind the thermostat tube) on the 5.9.
Assuming that this not strictly a difference between the 3.9 and the 5.9, it's reasonable to believe that there are some differences between a 95 5.9 and a 99 5.9 that can probably be attributed to the transition to OBD2 and year to year improvements.
Is this the case?
Should I try to get the 95 to make things easier?
Is it possible to add the vaccuum ports and sensor boss or should I get an earlier intake manifold (if I can't get the earlier motor)?
Old Jul 12, 2008 | 10:18 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: differences between 95 and 99 5.9
Engine wise there is no difference. But electronly yes lots of differnces. In the dak 1st gen forum there are a few who have done the 3.9 to 5.2 Here is a Good post https://dodgeforum.com/m_1276458/tm.htm
Now the 5.9 is almost exact to the 5.2 just differnt flywheel and harmonic ballancer. everything will work. So just get a pre 965.2 or 5.9 set up like comp wires injectors and all.
I have done a 5.2 to 5.9 swap. Its easy. Just do a search you can find lots of info.
Old Jul 14, 2008 | 07:40 PM
snoop1's Avatar
snoop1
Well swapped the 5.9s around and now I just gotta put it in. I just finished pulling the 3.9.
Thanks for the help!
