sea foam
Old Jul 16, 2008 | 12:06 PM
cks's Avatar
cks
Member
Default sea foam
thinking about running some seafoam through my truck is there any tricks to doing this and is it possible to harm my truck at all. thanks.
Old Jul 16, 2008 | 03:57 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Default RE: sea foam
Are you trying to get rid of a rough idle or misfire? Or did cleaning the TB correct the problem? Just curious because I'm about to clean my TB to try and get rid of a rough idle condition.
Old Jul 16, 2008 | 04:44 PM
rabbler's Avatar
rabbler
Get the engine hot and slowly pour it down the throttle body.
Shut the engine off and pour the last 10th of the can down and let it soak for a few hours.
Then take it for a drive on the highway and do some WOT bursts in 2nd gear (drive it hard) to blow out the carbon.
Seafom is O2 and converter safe.
You can also suck in in the PCV or brake booster if you like but I like to pour it directly down the throttlebody and IAC port to help clean those at the same time.
Old Jul 16, 2008 | 09:52 PM
cks's Avatar
cks
Member
no cleaning the iac did not fix it and i just got done seafoaming it and it smoked like crazy but fixed nothing. so next thing for me is cleaning the fuel injectors. which i will do tomorow.
