96 Ram brake upgrade
Old Jul 18, 2008 | 10:33 AM
neiondeion's Avatar
neiondeion
Default 96 Ram brake upgrade
Has anyone ever put the Viper calipers and rotors on a 96 model Ram? Wonering what is all involved if possible?
Old Aug 12, 2008 | 06:11 AM
HankL's Avatar
HankL
Fred Goeske at wheel adapters is a true brake expert has straightened out botched attempts at putting Viper brakes on Dakotas and Durangos.
http://www.wheeladapter.com/fred_goeske.asp
Call him and ask about putting Viper brakes on Rams.
My own advice is that unless you are trying to get rid of brake fad on the 4th or more application of the brakes,
like in racing or on very long downhills towing,
just try out different brake pads like the Hawk, Performance Friction or Bendix.
EGR Brakes also has upgrade kits.
http://www.egrbrakes.com/Dodge%20par...ges-select.htm
See 2 old posts below:
The following is from an article on Delco brake problems, but since 94-97 Rams have
Delco brakes too I thought I would post this.
Note the bit about increasing the rear brake wheel cylinders.
Has anyone had this done to a 1500 series Ram ? - HankL
begin quote:
Denny Mandeville, a former NAPA/ ASE Tech of the Year, says he's seen more
than his fair share of rotor-munching GM light trucks up at his shop in
beautiful Sedona, Arizona. Denny attributes the condition to GM flat out
underengineering the braking systems on these vehicles, coupled with owners'
tendency to overload them.
Denny's fix is to go one, sometimes two sizes larger on the wheel cylinders.
That equalizes the wear by biasing more of the braking force to the rear. In
extreme cases (conversion vans, contractor-owned trucks), Mandeville will
upgrade the entire rear braking system, going with larger wheel cylinders,
backing plates, shoes, etc.
As for the front brakes on these trucks, Denny has one rule he sticks to:
He'll cut the rotors just once, then swap in a fresh set on the next brake
job, regardless of how much meat is left. This, says Mandeville, will go a
long way toward extending pad life. I'm not sure why, but I suspect the
additional metal improves heat dissipation due to the greater swept area
exposed to the cooling air.
Jim Andrews of The Shop, in Fremont, California, has more than a casual
interest in pad-eating GM light trucks-he owns a 1994 4WD Chevy Suburban with
one hearty appetite. Like Mandeville, Andrews feels that the braking systems
on GM trucks are seriously undercapacity, given their weight and load
capacity. Unlike Mandeville, however, Jim prefers attacking the situation
where it rears its ugly head-up front.
Andrews points out that many brake parts companies (Raybestos, ACDelco and
Autospecialty, among others) now offer high-performance rotors for problem
vehicles that are directionally vented with spiral drilled holes or slots
milled into the face to drastically reduce operating temperatures. These
rotors alone will significantly extend the life of the pads, says Jim.
In case you're interested, Jim chose for his Suburban Autospecialty drilled
rotors with Performance Friction carbon fiber pads. To date, he said he's
logged about 30,000 miles with the potent combo, and still has 40% lining
material left! When you consider the abysmal life expectancy of the front pads
on GM light trucks, that's truly remarkable! Just like the two guys I just
mentioned.
end quote
original article at:
http://www.motor.com/MAGAZINE/Articles/052000_10.html
Over the past 3 weeks I have been changing out the brakes on my 1995 model
year 1500 Ram ClubCab 2wd.
The original factory front pads and rear shoes were changed out on this truck
back at 61,000 miles. Chrysler instruction sheet K6855323AB says these
original brake parts were a "Delco 243EE" set, although the front pads had
markings that said:
DM 128FE 7259/0 2/1 on the outboard pad
DM 128FE 8154 7259-1 1/1 on the inboard pad
Delco243EE**Delco243EE on rear shoes
I changed these original brake parts to 'improved' Mopar Replacements that
were recommended by Dodge in 1998 to improve brake performance in 1994-BR/BE
1996 Ram Truck 1500 Series.
This was a $156 kit bought at the dealer, part number 05013447AA.
I wrote up a report to DiRT on this Thu Apr 08 07:27:13 1999.
The instruction sheet K6855323AB included with the kit says that the improved
brake parts are a "Delco 224 FF" set of front pads BXH3EEE9278127E matched
with special rear shoes that are indeed marked Delco224FF.
These brake parts lasted on my truck from 61,000 miles to 140,000 miles, at
which time the front pads still had 3/16 inch thickness, but the rear shoe
thickness had worn away enough that the rivets had scored the brake drum
surface. I have to admit both styles of Delco parts lasted for a very good
life.
Prior to taking off the Delco 224FF brake parts I did 5 full stops with the
truck from 60 mph on a level asphalt road in dry 60-70 degree weather. I
would accelerate up to 60 mph then hit the brake pedal when I felt the front
tires hit an expansion joint in the road. I measured from the expansion joint
to where the nose of the truck stopped with a tape measure.
Results were:
219 feet
223 feet
204 feet
228 feet
197 feet
Average = 214 feet
When I had Bridgestone Dueler HL 245 75 R16 tires on this truck the tire tread
had so much dry traction that I could not cause the tires to skid in a panic
stop from 60 mph no matter how hard or quickly I hit the pedal.
In the above 5 tests I found that with Michelin LTX MS 245 75 R16 tire tread
pattern and rubber the truck would skid easily.
I have the standard Rear Wheel Anti-Lock (RWAL) system built by Kelsey Hayes,
not the optional ABS system.
Much of the variation from the worst 223 feet to the best 197 foot stop I feel
was due to skidding causing me to release the pedal momentarily. Even so, I
developed a flat spot on one of the rear wheels and there is now a slight
vibration - or maybe the Bendix drums aren't balanced properly.
I put Bendix AF462 shoes ($32.99) on the rear
with new Bendix #140660 drums ($54)
{both the above drums had 2 disturbing big balance weights welded to them}
replaced star wheel adjusters on both sides:
1531/F73182S USA Brake Parts ($12)
1530/F73181S, "Made in USA"
{the two sides have different left/right threads}
and replaced the original 1500 series
15/16 inch dia wheel cylinders with
1 and 1/16 inch diameter wheel cylinders:
TruTorque W79767/Raybestos WC37290 ($11) "Made in Italy"
that are standard equipment on 3500 series Rams.
The larger wheel cylinders
with their 28% greater piston area
bolted right in with no modifications needed.
With just the rear shoes changed to Bendix,
and wheel cylinders changed out to the larger diameter,
I did 5 more 60-0 stops:
199 feet
208
220
195
210
Average = 206 feet
I then:
changed the front pads to Bendix MKD369FM ($54.39),
polished the 4 rusty caliper sliding surfaces with a abrasive rubber wheel on
a Dremel tool,
lubed these 4 surfaces with a coating of NeverSieze the thickness of a
cigarette paper,
lubed the caliper bolts and sleeves with 10 drops of "BreakFree",
flushed and bled the brake fluid using two large bottles of Valvoline SynPower
Dot 3/4 brake fluid,
-- and then did 6 more 60-0 stops:
176 feet
191
177
200
167
192
Average = 184 feet
On these 6 stops the brake pedal had a good 'progressive' feel that allowed me
to stop with less skidding, but I think the pedal is not as firm as it should
be if all the air bubbles were out of the lines. I intend to bleed the 4
brakes again.
{Why did Dodge put a different size brake bleeder fitting on the rear versus
the front? Why is the front bleeder a metric wrench size, and the rear one
English?}
It is possible that I am feeling more brake pedal movement because it takes
28% more brake fluid to move the larger rear cylinders the same distance.
The above numbers are not as precise as I would like,
but my best guess is that these changes improved the
rear brakes about 4%,
and the front brakes improved about another 6%.
I feel better knowing I can stop about 30 feet shorter now.
My best two stops from 60 mph were 167 ft and 176 feet.
The best sports cars stop in 110-120 feet from 60 mph - at least according to
magazine reviews.
I guess we should all leave an extra 60-70 feet between our trucks and a
sports car in front of us - because they can stop shorter than we can. I have
seen a lot of Rams on the road with front bumper damage indicating they could
not stop in time.
