DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Ram Tech (https://dodgeforum.com/forum/2nd-gen-ram-tech-64/)
-   -   went muddin and now i'm effed! (https://dodgeforum.com/forum/2nd-gen-ram-tech/169140-went-muddin-and-now-im-effed.html)
Mike454 Jul 18, 2008 06:23 PM
well went muddin today and i got stuck in water up to the hood, well besides my interior being soaked, my CEL came on... its throwing 2 codes shift solenoid B stuck on and TCC circuit malfunction... tranny is shiftin all funny, it runs a little warm now (right around 200) and i think my alternator is howling at me! well this sucks! anyone else have this problem? am i stuck with just takin 'er in or any ideas? this electrical stuff bites...any help is greatly appreciated!
-Mike
zman17 Jul 18, 2008 07:25 PM
RE: went muddin and now i'm effed!
Park it and let it dry out for a couple days! You have to remove and clean up all the plugs on the tranny and the VSS on the rear end and the 02 sensors to start with.
And check both front and rear diff fluids for water before you drive it again. And if the water was that high you need to check all the fuses by the door and all the relays and fuses in the PDC under the hood! But I would first leave it open and let it dry out a few days.
Mike454 Jul 18, 2008 07:55 PM
yeah im in no hurry to screw it up anymore. i checked the codes again and another one came up, now the 3 are P1757 (shift solenoid or govenor sensor?) P0740 (Torque Converter Clutch circuit malf.) and a 3-4 shift malf. code. damn this sucks, i will do as you said and check all wiring to the best of my abilities. thanks for the input!
motorbrreath Jul 18, 2008 10:07 PM
drain all your fluids, and replace them. Spray electrical connections with WD-40 (wd means water displacemet)
I had some werid electrical problems after pressure washing the engine, but they went away when it dried up.
Cereal Killer Jul 18, 2008 11:57 PM
Your transmission might have water in it if it was that deep. They're not water proof.
Also how did the truck shut off? Did you shut if off cause you were stuck? Or did it stall out?
Mike454 Jul 19, 2008 01:39 AM
thanksmotorbrreath i plan on doing that tomorrow, and i got plenty of WD-40 so i will get to that as well.
cereal killer, as i plunged into the water the truck didn't die and i didn't turn it off either in fear i wouldn't get it going again, and i didn't want water going all up in my exhaust and such. whether or not that was a good idea i dont know, and i doubt my buddy coulda got me out without my tires spinnin as well, but who knows?
and now my alternator is squealin at me so i need to see what i can do there! the muddin trip was not worth all this crap!
Viper37 Jul 19, 2008 03:15 AM
ORIGINAL: motorbrreath
I thought you were boycotting this forum?
dillonjm Jul 19, 2008 06:05 PM
You need to drain the tranny fluid for sure. There is no way you were up to the hood without the fluid in there becoming contaminated. I buried mine and it turned the tranny fluid to pepto-bismol colored liquid. I would not drive it anymore until all the fluids are changed and sensors cleaned.
© 2026 MH Sub I, LLC dba Internet Brands
