4x4 actuator lines please HELP !!!!!!
Old Jul 21, 2008 | 09:37 PM
mfrump's Avatar
mfrump
Default 4x4 actuator lines please HELP !!!!!!
i have a 2000 ram 1500 4x4 and the lines that come off the actuator of the tranfercase area there is 4 outlets on this unit and i dont have a clue where they go because they got ripped off and i cant find a diagram can someone help please!!!!!
Old Jul 21, 2008 | 10:05 PM
Satellite's Avatar
Satellite
Default RE: 4x4 actuator lines please HELP !!!!!!
Try here: http://www.rm-indy.com/wavefiles/2001ramsrvcmanual.zip
Old Jul 21, 2008 | 10:38 PM
mfrump's Avatar
mfrump
great manual man that has alot of stuff it might take me awhile to find what i need but im sure its in there, by the way do you know if the 4x4 light works off of a vacuume related switch
Old Jul 22, 2008 | 09:18 AM
Aubrey's Avatar
Aubrey
Yes. It makes contact inside the CAD. If your light is staying on, it's not moving and is stuck in 4. If your light is staying off, it's not moving all the way to make contact and you could be in 2 or not fully engaged in 4.
Old Jul 24, 2008 | 01:14 PM
dhvaughan's Avatar
dhvaughan
light failure can also be a bad switch, dirty connector, torn off wires. check the switch w/ ohm meter. when the cad slides all the way over to engage, it closes the contact switch.
vac diagram (and more)..
http://www.dodgeram.org/tech/repair/..._engagment.htm
