94 Ram 1500 A/C problem
Old Jul 21, 2008 | 10:14 PM
tracerbob's Avatar
tracerbob
Default 94 Ram 1500 A/C problem
First post. A/C blows hot air and the compressor cycles on and off. I bypassed the low pressure switch, put a gauge on the low pressure sideand filled the system with freon. Hooked the switch back up, compressure runs fine now but no cool air. I did notice the low pressure line going into the condensor is cold but the high pressure line is warm/hot. Any ideas? The A/C hasn't work in a year or so. It's hot here in Florida!
Thanks in dvance
Bob
Old Jul 21, 2008 | 11:20 PM
krs7272's Avatar
krs7272
Default RE: 94 Ram 1500 A/C problem
Evaporator core is usually the case in these trucks. Just replaced mine 2 weeks ago.
Old Jul 22, 2008 | 10:11 AM
tracerbob's Avatar
tracerbob
Did you replace it yourself? If so, was it difficult?
Old Jul 22, 2008 | 12:45 PM
krs7272's Avatar
krs7272
Did it myself. Not bad took about 4 hrs. There's a complete how-to in the DIY link at the top of the page
Old Jul 22, 2008 | 03:55 PM
tracerbob's Avatar
tracerbob
krs7272, looked all over for the link in DIY. Only one I found was for a Dakota and that one was intense. Could I bother you to post the link?
Old Jul 22, 2008 | 06:03 PM
tracerbob's Avatar
tracerbob
Think I found it.
https://dodgeforum.com/m_879602/mpage_1/key_/tm.htm
Old Jul 22, 2008 | 06:50 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the vacuum lines to the dash control.
Old Jul 22, 2008 | 06:53 PM
zman17's Avatar
zman17
Iwent into a more detailed explanation
Old Jul 22, 2008 | 06:54 PM
zman17's Avatar
zman17
But I'm not wasting another ten minutes
Old Jul 22, 2008 | 06:59 PM
krs7272's Avatar
krs7272
Also what kind of pressure readings are you getting after adding freon? Even when my core leaked like a stuck pig it would at least hold for a few maybe and hour.
