leaking transmission
Old Jul 28, 2008 | 01:44 AM
dodge_96's Avatar
dodge_96
Default leaking transmission
i have a 96 ram 1500 4x4 318 5.2l. i just changed the front pump seal on the tranny and something is still leaking. what other seal could be leaking?
Old Jul 30, 2008 | 11:06 AM
bigmudder77's Avatar
bigmudder77
Default RE: leaking transmission
where is it leaking from? mine was leaking from the stupid plastic lines going in to the tranny or plastic clips i should say
Old Jul 30, 2008 | 10:35 PM
dodge_96's Avatar
dodge_96
its leaking from the bell housing, it could be the o-ring seal or gasket for the pump. could it be the torque converter leaking. also when i put it in reverse and press the gas it starts leaking like no other.
Old Aug 2, 2008 | 03:15 PM
dodge_96's Avatar
dodge_96
here's what i think the problem is.
https://dodgeforum.com/m_424643/tm.htm
(look at the 4th post)
in order to fix it would i have to rebuild it.
