Reading error codes on an 99 Ram 1500
Subscribe
Jul 29, 2008 | 09:09 AM
My father has a 1999 Ram 1500 w/ V8 Magnum engine 2WD. He had a problem with the brake light and ABS light that turned out to be a loose connector to the speed sensor at the rear differential. Since he corrected it, the check engine light has come on. He bought a code reader, but he said he can't locate the plug to check the code and possibly clear it. Anyone know the physical location of the connector to plug in the code reader? Thanks in advance for your help.
Reply 0
Jul 29, 2008 | 09:41 AM
RE: Reading error codes on an 99 Ram 1500
The plug to read the codes on my 99 Ram is under the dash to the right of the steering column.
Reply 0
Subscribe
