Replacing Cigarette Lighter
Old Jul 29, 2008 | 05:30 PM
sivadr's Avatar
sivadr
Default Replacing Cigarette Lighter
The black plastic that holds the cigarette housing in the dash broke. I unhooked the cigarette housing to the cable behind the ashtray. Now that I have a newplastic holder,how doI reattach the cable back to the cigarette housing? Do I need to remove the bottom dash or the cup holder to hook the cable into the housing? If so, I do I do so. I have a 2001 1500 Dodge Ram. Thanks
Old Jul 29, 2008 | 08:34 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Replacing Cigarette Lighter
you can reach it by removing the cup holder. there are 4 or 5 screws holding on the cup holder. Must pull the black bezel that surrounds the instrument cluster.
Old Jul 29, 2008 | 08:36 PM
aim4squirrels
Tilt the wheel down fully and shift into 1st gear, gently pry straight out around the edge of the bezel until it pops out. follow it around the outside and lift upward to remove.
Old Jul 29, 2008 | 08:37 PM
aim4squirrels
look for the screws near the stereo, and 2 are in the back of the cup holder when its down.
Old Jul 29, 2008 | 08:38 PM
aim4squirrels
you can also remove the cover plate under the steering wheel, but you need a #25 torx driver.
