brakes
Old Jul 31, 2008 | 08:07 AM
kitchenrat1's Avatar
kitchenrat1
Default brakes
Had a better description, but can't post properly. Pulls to the right after changing brakes, rotors and bearings. Why?
Old Jul 31, 2008 | 09:49 AM
kitchenrat1
Default RE: brakes
Wile driving it pulls slightly to the right. While braking it pulls sharply. Also the left side squeals slightly. Possible caliper not compressing properly on the left?
Old Jul 31, 2008 | 09:52 AM
kitchenrat1
Default RE: brakes
Also did not have torque wrench to tighten hub nuts. But pretty sure I tightened them evenly and then backed them off 1/4 turn. Possible that they were not tightened evenly? Would that cause the above problems?
Old Jul 31, 2008 | 04:10 PM
jasonw's Avatar
jasonw
Site Moderator
Default RE: brakes
Bump.
Old Jul 31, 2008 | 04:24 PM
Mowhawk's Avatar
Mowhawk
Default RE: brakes
alignment? My alignments off a little to the right and it pulls when i break, also when i turn right i can hear the left side squeeling a little, though I dont know if the squeel is from the alignment issue.
Old Jul 31, 2008 | 06:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: brakes
Did you clean the slides so the calipers move freely?
Old Jul 31, 2008 | 06:08 PM
zman17's Avatar
zman17
Default RE: brakes
And maybe the piston is stuck and you need a new caliper
Old Jul 31, 2008 | 08:08 PM
kitchenrat1
Default RE: brakes
I'll check the slides tomorrow. I also was thinking the piston was not working. Will also check tomorrow. The thing is that it never did this before the replacement so it must be something I did.
