1996 1/2 ton ram 5.9 antifreeze smell
Old Aug 12, 2008 | 03:21 PM
rubadub's Avatar
rubadub
Junior Member
Default 1996 1/2 ton ram 5.9 antifreeze smell
My pickup keeps using a little bit of antifreeze and I can smell antifreeze inside the cab when I drive it, any ideas on where it might be leakin! Its a 1996 dodge 1/2 ton auto trans with overdrive, towing package 5.9 engine.
Please and thank you.
Rob
http://www.1969supersport.com
Old Aug 12, 2008 | 03:23 PM
MEINEKEMAN1's Avatar
MEINEKEMAN1
Heater core.
Old Aug 12, 2008 | 03:31 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by MEINEKEMAN1
Heater core.
X2. It's your heater core. There's a write-up in the DIY about changing it.
Old Aug 12, 2008 | 03:47 PM
rubadub's Avatar
rubadub
Junior Member
Thanks men that was a quick response, I'll do the search, but another question, if it was the heater core would the carpeting get wet or would I be able to see a drip someplace, thanks again.
Rob
Old Aug 12, 2008 | 03:50 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Rob
Sometimes. It could also be dripping out where the A/C condenser drains on the passenger side of the cabin.
Here's your start: https://dodgeforum.com/forum/showthread.php?t=117182
Old Aug 12, 2008 | 04:24 PM
Aubrey's Avatar
Aubrey
Heater core and not necessarily.
Old Aug 12, 2008 | 04:42 PM
rubadub's Avatar
rubadub
Junior Member
Several responses allready, you guys are great.
So if its not necessarily the heater core what else could it be.
I let it set for a month and changed the oil and watched for any water in it, like maybe a head gasket.
I was talking to a guy with a 2001 ram with the 5.9 and he said it might be a seal or valve underneath the timing cover and you also have to pull the oil pan to get at it.
The heater core would be easier to change I would think then the seal or valve the guy I talked to mentioned.
Should I get the wallet out and get it pressure checked first, or isn't it worth it.
Rob
Old Aug 12, 2008 | 04:48 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Rob
I think Aubrey meant that it won't necessarily leak inside of the passenger cabin. Mine had pinholes in it and I could smell antifreeze often, but there was never any sign of leakage.
I don't know where that guy got his information, but IMHO the smell of coolant in the cabin means the heater core is going. Be advised: Set aside a Saturday afternoon for this job and completely read the DIY on it. This is very cumbersome the first time you do it. A shop will charge upwards of $800 for this repair because the entire dash must be removed.
Old Aug 12, 2008 | 05:16 PM
rubadub's Avatar
rubadub
Junior Member
The guy with the 2001 ram lives about two blocks from me, he said he could smell it for a long time and they really hunted hard trying to find the leak, he had to keep adding antifreeze.
Then his son in law used it to haul a car on a trailer and the seal or valve let loose and sprayed antifreeze around.
Listening to you guys, it sounds like the heater core, thanks again, you guys are great.
Rob
Old Aug 12, 2008 | 05:23 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Rob
OK, now I understand. I'm betting his coolant level was always low and they smelled it outside of the truck versus your smelling it in the cabin. Very different animals, but nevertheless very frustrating.
