Pinging?
Old Aug 13, 2008 | 01:15 AM
rabbler's Avatar
rabbler
Yes you can get NGK plugs in a cooler heat range.
RC10LC4 is a colder Champion plug of the same type. Get the parts guy to cross it to NGK
NGK ZFR5F11 and NGK ZFR6F11 are colder types that popular. The (6) is colder than the (5)
Champion Truck Plugs are also popular and have been known to reduce pinging.
Old Aug 13, 2008 | 08:37 AM
Mowhawk's Avatar
Mowhawk
ill see if it continues after this tank of gas, if it does ill swap out plugs and check my plenum
Old Aug 13, 2008 | 08:59 AM
aim4squirrels's Avatar
aim4squirrels
Originally Posted by CPTAFW163
I just moved to CA and i have the mopar chip which calls for at least 92. It sucks.
Try to run it anyway, if it doesn't ping, you're fine. the 92 octane number on the pcm isn't a magic number that once you hit it it works, it's a guideline. There are variances in gas from tanker to tanker and supplier to supplier.
Old Aug 13, 2008 | 09:06 AM
Mowhawk's Avatar
Mowhawk
Did i mention you guys are amazing with responses(no gayness intended). This place rules.
Old Aug 13, 2008 | 10:45 AM
HankL's Avatar
HankL
Cooler heat range sparkplugs of any brand will not cure the pinging in Rams,
but simply unscrewing the sparkplugs
will knock enough carbon deposits loose in the combustion chamber
that the engine will quit pinging for 500 to 1000 miles.
I was fooled many times like this and with many different sparkplugs before I understood what was going on.
Chrysler's official 'Combustion Chamber Cleaner' is about $8 per spray can and does a very good job of cleaning out carbon from the backsides of the intake valves, the piston crowns, and it you feed some through the IAC port it will safely clean that too.
In the very worse cases, unscrew the sparkplugs, spray the CCC into the eight open plug holes, let sit 30 minutes, then screw the sparkplugs back in and start up the engine and spray some more CCC in.
This does create clouds of black smoke.
If you want to experiment, do just one sparkplug hole at a time this way and you will discover which of your 8 cylinders is causing the pinging problem. Most of the time it seems to be cylinders 7 & 8 which are the back cylinders.
I have done many experiments on eliminating pinging in Magnum V8s
and the CCC treatments are what works quickly.
It is also the official Chrysler procedure.
CCC works better than SeaFoam
There is another interesting way to get rid of carbon deposits and pinging
using the water that drains out of your air conditioning.
see the 'Danger, Danger, Danger' post in the link below
http://tinyurl.com/2rb8cq
