replace water pump
Old Aug 15, 2008 | 07:28 AM
dodgies's Avatar
dodgies
Default replace water pump
How do you replace the water pump on a 2000 Dodge Ram 1500? tnx..newbie here..
______________
dodgies74613315
Old Aug 15, 2008 | 07:33 AM
kurtdaniel's Avatar
kurtdaniel
its not that hard to work on the pump..first, remove the shroud, fan, belt and then the bolts. Its just as easy to replace after you have unbolted it..Good luck..
Old Aug 15, 2008 | 07:34 AM
dodgies's Avatar
dodgies
tnx so much
Old Dec 11, 2008 | 04:05 AM
kurtdaniel's Avatar
kurtdaniel
heres a more complete and step by step procedures in doing it.. i hope it helps..https://dodgeforum.com/forum/diy-do-...e00ram360.html
(cricket)
hp?act=post&do=rehp?act=post&do=re
fuel mileage for kurt E. daniel
rum/forumdisplay.php?f=
Old Dec 11, 2008 | 07:10 AM
98DodgeRam1500's Avatar
98DodgeRam1500
While you got that all apart, might as well consider a new timing chain, main seal, T-Stat... and maybe a new fan clutch too.
Heck, a new serpentine belt?
all depending on how many miles you have, and how many you intend on putting on the truck...
OH, and replace all your hoses, the two that go to he rad, and the bypass hose too!
Last edited by 98DodgeRam1500; Dec 11, 2008 at 07:11 AM. Reason: added more parts to be replaced.
Old Dec 11, 2008 | 07:24 AM
dhvaughan's Avatar
dhvaughan
good time to fix the plenum too.
Old Dec 11, 2008 | 07:12 PM
98DodgeRam1500
Anytime is a good time to fix that thing.
