Gear Stacking?
Old Aug 20, 2008 | 11:46 AM
asimpson97d's Avatar
asimpson97d
Default Gear Stacking?
I am having trouble with gears in my 97 Ram. Built a 426 stroker with 4:88 gear ratio and keep rippin teeth off the ring gear. I kept thinking it was bad gears. A freind of mine said his Ford 9 inch was doing the same thing until he got a different carrier. He said that the previous carrier was causing gear stacking from a stand still or slow moving take off which was hurting the gears( also ring gear teeth) Does anyone know if someone makes a different carrier for these trucks? The carrier in it now is from Randy Ring and Pinion when I installed 4:56 gears. I haven't clled Randy's (little pissed with them at the moment). Just wondering if anyone has seen this problem or know anything about a different carrier. thanks.
Old Aug 20, 2008 | 04:07 PM
rabbler's Avatar
rabbler
Who's been doing the installation?
Usually the pinion is the weak point.
What kind or torque does your engine put out?
Old Aug 20, 2008 | 04:51 PM
asimpson97d
Trust me...set is on the money. I never had the motor dynoed, but its bad! the pinion is hold up fine. the ring gear is taking the beating.
Old Aug 20, 2008 | 07:09 PM
Rockyhigh360's Avatar
Rockyhigh360
Dana Spicer makes the strongest gears for your money. If your running 35 spline axles, better go with a chromoly ring set up. It will never break. Also stay away from Yukon and Genuine. Overseas crap. Overall, the best carrier is a detroit full for that kind of torque.
