need to retrieve codes....how?
Was wondering what pins to jump with a paperclip....I don't have a code scanner to read a dodge vehicle.
Iam throwing a check engine light.
Truck runs fine, as long as you don't get on it. Once you give it any real throttle it revs but hardly moves at all. Can hear a whistle noise from somewhere, can't pinpoint it though.
Need help in a hurry....outside right now working on it.
thanks
Jamie
thanks
Jamie
https://dodgeforum.com/m_63384/tm.htm
You might be able to pull it this way but using a code reader is not a bad idea.
Autozone and other parts stores will pull the code for you for free.
And in the general tech forum you can look up the OBD II codes.
https://dodgeforum.com/m_126008/tm.htm
WHISTLE MAY BE A VACUUM LEAK. SPRAY CARB & CHOKE CLEANER ARROUND LINES WHEN VEHICLE IS COLD. IF THERE IS A LEAK, THE CLEANER WILL SUCK IN THE LEAK AND CHOKE OUT THE MOTOR. LOOK IN THAT AREA FOR A LOOSE, BROKEN, OS CRACKED LINE. REVS HIGH BUT HARDLY MOVES SOUNDS LIKE A TRANSMISSION PROBLEM. KEEP US POSTED. & GOOD LUCK
ok found this out..... Cyl 1,2,3,6 have stored a code as quote: Not Firing when under load.
So....hmmmmmmmmm what you all make of this?
iam guessing at distributor cap? maybe cracked due to the cold?
thanks for help in advance
