Need some help quick
Old Aug 30, 2008 | 08:48 PM
Rooster1948's Avatar
Rooster1948
New Member
Default Need some help quick
Have a '94 1500 2WD, 360 Auto. Yesterday, the A/C blower quit and the power windows quit working at the same time. The ABS, AirBag and Brake lights lit up. All other accessories work and the truck starts and runs fine. All fuses and curcuit braakers are OK. Any ideas?
Old Aug 31, 2008 | 01:50 AM
jasonw's Avatar
jasonw
Site Moderator
Circuit beakers? I didn't know our trucks had any of those.
You checked both the fuses in the PDC (under the hood) and on the panel between the dash and the door on the driver's side?
Old Aug 31, 2008 | 09:29 AM
Rooster1948
New Member
Haven't checked under the hood, but fuse panel in end of dash is OK. Thanks, will look there.
Old Aug 31, 2008 | 09:41 AM
aim4squirrels's Avatar
aim4squirrels
Inspect all fuses carefully with a flashlight. Sometimes they don't blow with a fury of burn marks.
Old Aug 31, 2008 | 02:17 PM
charlie1935's Avatar
charlie1935
I have had fuses break where it could not be seen, had to check them for continuity with a meter.
Old Sep 1, 2008 | 02:50 PM
Rooster1948
New Member
Thanks to all. But how would a blown fuse explain the warning lights illuminating? Headed to the garage now with the multi meter and will update with findings.
Old Sep 1, 2008 | 03:26 PM
Rooster1948
New Member
Found it. Ignition switch was burned at post 4&5. That is what turns on the heavy accessories.
Thanks to allthat helped.
