Optima vs House Brand Battery. Is it really worth the money?
whatever battery you choose
try to avoid one with the dual connections
that has those extra GM style tapped holes on the side
A previous battery like that leaked acid on my Ram
and I have seen others with similar leaks
I have both a Duralast in my wifes car and a Optima in my truck the Duralast is 4 years old The Optima is 5 years old and has been in two trucks Both have been great just don't get a Exide battery. Exide battery Co. had to buy a complete vehical wiring harness, radiator, fan shroud, hood, fender, grill, paint job due to a new battery exploding in my 88 Dime. They deterimed it was defective and the plates shorted out cuzing a spark inside the battery witch cuzed it to explode.
Well, I ended up buying an Oreilly SuperStart. Its rated at 750 CCA and is a 6 year battery, and I came out paying $86. The Optima I wanted was $169 or $179, and even with a $25 rebate, I'd be paying $60-70 for an extra 2 years. I'm not even sure I'll have this truck for 6 years, depending on the price of fuel. Thanks for all of your input. The truck will hopefully be started this afternoon after I finish reinstalling everything on the fenders, which is a pita..
I think the OEM was 750 CCA but I'm not 100% on that. I really think that's what it was though. They also listed a 700 CCA but I had the 750 one stock so wanted that again. I paid $100.52 or something similar. It was $100. something with tax and all. Our dealer is usually high. I called around and found one 3 hours away with the lowest price. Our dealer wouldn't match that but they came down quite a bit so I paid that rather than driving. Our dealer is a rip off but sometimes it's just better because it's soo close. I normally just look up prices online and tell them to match that retail and they usually will. They normally are way above retail if you don't haggle with them. I couldn't find the battery online so called around.
It helps if you buy through a shop, since they can usually get around a 30% discount. The battery I walked out with was 750 CCA and 800 or 850 Regular CA. It started up fine, so we'll see how long it lasts.
another option:
http://www.milbatteries.com/hawker/index.html
link to more info on vehicle batteries
http://www.batteryfaq.org/
