4x4 sensor? need help?
Old Sep 1, 2008 | 07:59 PM
riceater45's Avatar
riceater45
Default 4x4 sensor? need help?
alright my 4x4 light is stuck on. but im not in 4 wheel. how do i fix that?
Old Sep 1, 2008 | 08:32 PM
dhvaughan's Avatar
dhvaughan
on the end of the cad, drivers side is the switch for the light. when the cad slides to the drivers side, it depresses a plunger/or makes contact. clean the electrical connector, test the switch in on/off position. you can remove the switch for checking and cleaning the contacts. if bad, the switch is available at all auto parts stores for $10-20.
http://www.dodgeram.org/tech/repair/..._engagment.htm
http://www.4x4wire.com/dodge/tech/solid_axle_cad/
