2001 Dodge Ram 1500 Tranny Problem
Old Sep 3, 2008 | 06:56 PM
tampapirate's Avatar
tampapirate
New Member
Default 2001 Dodge Ram 1500 Tranny Problem
I have a 2001 Dodge Ram 1500 4x2, recently I lost reverse in the transmission and I also noticed it sounded like it was rough shifting in all forward gears. When was changing the tranny fluid and filter this weekend I found something scary in the pan. They looked like small pieces of metal maybe 5mm thick and 1/4" wide. I put them all together and they formed a half semi-circle. Is this a band or what does anybody think it can be? Also what will be the solution to fix the reverse problem.
Note: Since I changed the fluid the forward gears all sound fine and shift smoothly.
Thanks very much,
The Tampa Pirate
Old Sep 3, 2008 | 07:54 PM
mcsd913's Avatar
mcsd913
i had the same problem...Had to get it rebuilt a week later
Old Sep 3, 2008 | 08:08 PM
MonteC's Avatar
MonteC
Sorry bud. Your reverse band is toast. Ive gotten a couple in with that problem. The reverse band apply servo broke and caused the band to drag on the drum and tore the band down to metal and ate into the reverse drum. Its time for a rebuild.
Old Sep 3, 2008 | 08:57 PM
tampapirate
New Member
Default Arrgghh
Thanks guys I really appreciate the info. Guess its got to get done. How much should I expect to pay if I may ask? Is it possible to DIY. I did my wife's 96 Dodge Caravan myself.
Old Sep 3, 2008 | 09:26 PM
MonteC's Avatar
MonteC
If you did a 4psd auto in a caravan then you can tackle the 4psd auto in your truck. Easy as pie.
I would charge at the MOST 1500 bucks including R&R for a rebuild on an A518.
Old Sep 3, 2008 | 09:32 PM
tampapirate
New Member
Default Thanks
Thanks Monte.... I appreciate it. Guess I better start finding a rebuilt transmission.
Old Sep 4, 2008 | 09:59 PM
mcsd913's Avatar
mcsd913
i payed 1300 for mine (still paying for it..needed to get credit started)
