tranny leak ??
Old Sep 13, 2008 | 08:01 PM
99DRAM31887's Avatar
99DRAM31887
Default tranny leak ??
is it possible for ur tranny to leak from the yoke ?
Old Sep 14, 2008 | 01:18 AM
MonteC's Avatar
MonteC
What do you mean? From around the slip in yolk, where it meets the seal or from the back of the slip in yolk?
Old Sep 14, 2008 | 01:28 AM
99DRAM31887
yes like where the yoke comes out of the back of the tranny and meets the rear drive shaft.... right next to the gas tank ...
Old Sep 14, 2008 | 01:33 AM
99DRAM31887
i mean the leak is so small its unreal it leaves like a puddle the size of a 50 cent peice over night or smaller .... and i rolled under the truck and i saw the fluid on the yolk and its also being slug on the heat sheild of my gas tank.... so but my tranny is topped off and i put a slick 50 high mileage tranny tratment bottle in there ant topped it off this past thursday so iam hopin it might fix it if possible if not i will get it looked at
Old Sep 14, 2008 | 02:03 AM
charlie1935's Avatar
charlie1935
There is a seal in the tail shaft housing that can cause your leak. It can be replaced easily. Just remove the drive shaft, pry the old one out carefully and drive the new one in. Some times there will be a worn ring around the yoke. You can get a seal with a wear ring that gos on the yoke so the new seal doesn't leak.
Old Sep 14, 2008 | 02:05 AM
99DRAM31887
sweet thanks
Old Sep 14, 2008 | 09:48 AM
aim4squirrels's Avatar
aim4squirrels
tranny additives = bad idea
Old Sep 14, 2008 | 10:31 AM
MonteC's Avatar
MonteC
x2 Especially the "stop leak" ones. Those are horrible.
Old Sep 14, 2008 | 12:04 PM
99DRAM31887
well this one was just to help with hard shifting and other things it was like the ones that just said to stop leaks lol ... but i plan on tearing it apart here ina little while
