hearing grinding noise from t-case? or something maybe something else?
Old Sep 18, 2008 | 12:13 AM
Pontgt01's Avatar
Pontgt01
Default hearing grinding noise from t-case? or something maybe something else?
ok so here's my problem today i was trying to remove the tail housing on the transfer case cause from my understanding the snap ring in the rear tends to break allowing the gears in the t-case to grind a bit in drive. so i bought the snap ring thinking that this shouldn't take long. couple of hours later i still can get it. i removed the driveshaft and then removed the 4 bolts holding on to the t-case tail housing and here's the problem the tail housing refuses to come off like i said i removed the driveshaft and the 4 bolts holding the tail housing on and nothing! is there a trick to removing it? or does it really just slide off? i even called dodge and they told me that it should slide right off but nothing happens. so what do you guys think it could be? i'm about ready to stick a prybar in between to try and get the thing off. oh and the reason i am trying install the snap ring is that when i drive i get a grinding noise coming from the front right by my foot and when i slow down it goes away the u-joints in the rear are fine as i inspected them when i removed the driveshaft so any ideas? i have a 241 DHD transfer case in my 99 ram 5.9 any input would be great.
Old Sep 20, 2008 | 11:03 PM
Pontgt01's Avatar
Pontgt01
anybody? anybody at all?
Old Apr 15, 2009 | 09:21 PM
huttbutt's Avatar
huttbutt
Try smacking it with a rubber mallet?
Old Apr 15, 2009 | 09:25 PM
dhvaughan's Avatar
dhvaughan
start with a gentle smack.
Old Apr 16, 2009 | 08:22 AM
olyelr's Avatar
olyelr
Uh oh, don't let this happen http://www.pavementsucks.com/forums/...p?post=1312641 , and don't replace the snap ring with another one, get this http://www.drivetrain.com/parts_cata...ase_saver.html .
Sorry, but I cant help you with the dismantling portion of it. I have not done it before. But anyway, good luck.
Old Apr 16, 2009 | 11:26 AM
PartsChaser's Avatar
PartsChaser
+1 on the T-case Saver. I am going to do the same thing to mine, please post when you get it separated and fixed!
