What plugs w/ MSD 6A?
Old Sep 20, 2008 | 07:55 PM
Rockyhigh360's Avatar
Rockyhigh360
Default What plugs w/ MSD 6A?
Just want to thank everybodies input @ the forum, great site! So i have a 360 w/ the 6A and blaster coil, any recomends on plugs? Tried the E3 w/ it and no go, dropped the power, rough idle, engine light. Which autolites or NGK would be best for the 6A?
Old Sep 20, 2008 | 08:23 PM
padodgeram's Avatar
padodgeram
3923 autolite can be found at walmart , gap at .040
Old Sep 20, 2008 | 09:06 PM
motorbrreath's Avatar
motorbrreath
autolites are the best for our trucks IMO
Old Sep 20, 2008 | 09:08 PM
jasonw's Avatar
jasonw
Site Moderator
Some don't have as much like with the Autolites as some here though. Champion Truck Plugs are also thought of as good, and I am running the NGK Iridium IX plugs and I like them.
Old Sep 21, 2008 | 12:43 AM
rabbler's Avatar
rabbler
I would think a platinum or iridium would be a good choice.
The MSD's are hard on plugs due to the multiple sparks.
I would go with NGK or Champion and try a slightly cooler premium plug
Old Sep 21, 2008 | 06:54 AM
HankL's Avatar
HankL
you might check the current flowing to the MSD from the PCM computer
I can remember at least two past posts where a MDS 6a installation resulted in a failed Thyristor inside the PCM computer that drives oem ignition circuit, which required a replacement PCM
other posts have said the distributor cap and rotor have much shorter lives with a MSD attached
Old Sep 21, 2008 | 09:33 AM
lastrights's Avatar
lastrights
jason whats the part number for your NGK Iridium IX plugs
Old Sep 21, 2008 | 08:35 PM
motorbrreath
you gotta upgrade your cap and rotor to a mopar performance one with brass tips to help its life.
its just a fact of life with the msd. it eats plugs and cap and rotors.
it needs 8mm wires as well.
Old Sep 21, 2008 | 09:28 PM
rabbler's Avatar
rabbler
I think the proper tach adapter (Accell or other) will prevent that as well as ignition codes.
Old Sep 22, 2008 | 02:26 AM
jasonw's Avatar
jasonw
Site Moderator
I believe they are part number ZFR6FIX-11.
