window wont roll up
Check the wires going through the rubber boot at the door jamb. I suggest you download the free service manual at top of page and check the relay, fuse and wiring . If that all checks out get a switch from the JY and try.
Had a similar situation on my '96
(1) passanger window would not operate from drivers side.
(2) after some time(many months ) passanger window would not operate from either passanger or drivers side.
(3) Removed both switches, filled both switches with WD-40, operated several time, & with my ohm meter attempted to find a problem. and draw a wiring diagram.
(4) exaperased with finding no fault with the switches, called the Mopar dealer to make sure the switches were in stock. Reinstalled the old switches to make sure I didn't lose any parts.
(5) both switches started to work and have been working for more than three years. (Knock on wood)
I suggest you remove the switches, fill all the opening with WD-40, operate them numorous times & give them a try. Might save you a bunch of bucks.
