Code p1281 engine too cold?
Old Sep 24, 2008 | 05:50 PM
tazman6789's Avatar
tazman6789
Default Code p1281 engine too cold?
Ok my check engine light NEVER came on, i got a hypertech programmer today and it said i had a code, the programmer came back with code p1281 Engine is cold too long "If engine does not warm up to 176F while driving for 20 minutes after start" i put a 180F thermostat in like 6 months ago when i did my plenum. Is this something to just go eh whatever to? or something i should investigate.
Old Sep 24, 2008 | 06:07 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You are OK as long as the CEL doesn't come on. A lot of people here use the 180 T-stat.
Old Sep 24, 2008 | 07:00 PM
charlie1935's Avatar
charlie1935
A 180 thermostat should start to open at 180 so it should not be running that cool (I think).
Old Sep 24, 2008 | 09:03 PM
DODGEIT105's Avatar
DODGEIT105
I put a 180 degree t-stat in several years ago. I live in Florida so our winter weather doesn't set a CEL. However I did have that happen one Xmas when in the N. Carolina Mountains and it was 25 degrees out one morning. I reset it after the truck warmed up with my programmer and it wasn't an issue after that. What is your current temperatures overnight?
Old Sep 25, 2008 | 12:09 PM
tazman6789's Avatar
tazman6789
currently its been getting in the 40's at night, but the cel light never came on so i didnt even know the code was there
Old Sep 25, 2008 | 06:24 PM
zman17's Avatar
zman17
The HyperTech is telling you the code is there. If the code was there before you used it, the stock PCM would have given you a light. I would not worry about it.
