Grinding in the rear axle
Old Oct 1, 2008 | 04:50 PM
Dav2236's Avatar
Dav2236
Default Grinding in the rear axle
I just bought a 98 SST and there is a grinding noise comming from the rear. I talked to a guy at work and he said that those axles were notorious for the pinion bearing going out. Does anybody agree or have any other thoughts.
Old Oct 1, 2008 | 08:40 PM
DODGEIT105's Avatar
DODGEIT105
If it has the Chrysler 9.25 rear diff. then yes it seems to be a common problem. I know of several that have had those problems including myself. Mine is a 01' and I have replaced the pinion bearing as well as the clutch pack for the trac-loc. Truck currently has 151,000 + on it.
Old Oct 1, 2008 | 09:09 PM
jasonw's Avatar
jasonw
Site Moderator
I've heard of the LSDs breaking a lot, but never heard of the pinion bearing problem with the Chrysler 9.25s.
Old Oct 1, 2008 | 09:25 PM
dhvaughan's Avatar
dhvaughan
the 9.25 open is fine. the LSD is crap, with broken pieces floating around.
remove the cover and see what you find.
http://www.pavementsucks.com/tech/diff.php
Old Oct 2, 2008 | 08:32 AM
dodge@1997's Avatar
dodge@1997
How do you tell what size you have? I know I have 4.10 gears. My yruck is a 2500.
Old Oct 2, 2008 | 10:19 AM
dodgeguy97's Avatar
dodgeguy97
its all in how you take care of them service them and use the right oils and friction modifiers i work in a garage 90% of people neglect the vechicle's
