Transmission problems
Old Oct 11, 2008 | 09:54 PM
MonteC's Avatar
MonteC
Ok its a mechanical governor. Sounds like you have governor pressure issues. At light throttle the transmission has enough time to build up governor pressure, plus it doesnt need as much governor pressure to shift. When you accelerate heavily it gives the transmission less time and it requires more governor pressure to up shift, especially the later the shift.
For now, adjust the cable. Grab a bottle of smart bend or lube guard (red bottle) and dump it in.
Old Oct 11, 2008 | 11:19 PM
master2090's Avatar
master2090
is there a specific thing i should be looking for when adjusting it?
by the way i appreciate all the help.
Old Oct 12, 2008 | 12:13 AM
master2090's Avatar
master2090
also do you think i should change the tranny fluid since i have no idea when it was done last?
Old Oct 13, 2008 | 06:14 AM
MonteC's Avatar
MonteC
yes. That is a good idea.
