What Is This
Old Oct 10, 2008 | 12:38 AM
Laramie1997's Avatar
Laramie1997
Default What Is This
Ok, so today I tried to fix the vacuum leak to my 4X4, and in the process I found this: http://i412.photobucket.com/albums/p...9081538-02.jpg
http://i412.photobucket.com/albums/p...ysteryHose.jpg
Now, I had a severe front end collison in my truck a few years back, and i took my truck to my local body shop.
When I got my truck back it seems the body shop thought that just because they had to unhook parts of the truck, that they didnt have to hook the back up when they were done! I could spend a whole page explaining all the wire connections and hoses they left to just hang, but I just want to find out where this hooks to.
Thanks
Old Oct 10, 2008 | 01:21 AM
dodgeguy97's Avatar
dodgeguy97
hard to tell not to good of pic but looks like axle vent tube is it on the passenger side if so it needs to be up on the inside of the inner fender well inside the engine compartment clips right to the inner fender when mine was hanging there it pushed diff grease all over my inner wheel well
Old Oct 10, 2008 | 01:36 AM
Laramie1997
no this is on the driver side i already re tied the drain line on the passenger side
Old Oct 10, 2008 | 02:16 AM
dodgeguy97's Avatar
dodgeguy97
ok my bad well sense its on the driver side possibly emission hose maybr from gas tank to charcole canister its hard to tell without seeing up close i will check my truck in the morning and see does it run along the frame
Old Oct 10, 2008 | 09:19 AM
Laramie1997
No it doesnt run along the frame the rubber part of the hose runs up over the top of the transmission havent really tried to see where it goes from there. on my truck there would be no way that hose could run to evap canister, unless there is a whole peice of hose missing. Knowing what kind of job has been done to my truck, I wouldnt think twice about a whole chunk of hose missing.
Old Oct 10, 2008 | 06:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Take some better pix with a better perspective of where this hose is! And I'll look at my 98 in the AM,as I have work to do on it . I gotta say those pix kinda suck! LOL
