Fuel Guage is WAY off
Old Feb 6, 2005 | 10:51 PM
Fiah's Avatar
Fiah
Default Fuel Guage is WAY off
Today I was driving like normal and all of a sudden my truck ( 01 1500 ) started missing and jerking and I looked at the fuel gaauge and It showed 1/4 of a tank. Well about a min later the truck died. I checked the tank with a rod and it showed dead empty. Could this be the guage or the fuel reader inside the tank? I know about zero when it comes to trucks so I figured I would ask here for some advice. Thx in advance.
BTW Ive had the truck only a month and it was only the second time I was around 1/4 of a tank. The first time was when I bought the truck it was around 1/8 and was fine..then I topped it off from there.
Old Feb 6, 2005 | 10:58 PM
moparturd's Avatar
moparturd
Default RE: Fuel Guage is WAY off
Sending unit would be my guess.
Old Feb 6, 2005 | 11:36 PM
440Duster's Avatar
440Duster
Usually the sending unit is the problem. Either the float arm on the sending unit is bent down too far or there is a bad spot in the rheostat element on the sending unit. You can bend the float arm on the sending unit if you jam a hose into the fuel tank during an attempt to siphon fuel, provided you can even get the hose in past the anti-siphon mechanism in the fuel fill neck.
I would plan on replacing the sending unit or just remember that you are nearing empty at 1/4 tank!!!
Old Feb 7, 2005 | 01:01 AM
TPSDODGE's Avatar
TPSDODGE
my 95 does the same thing...i think i gonna replce the sending unit good place to buy www.rockauto.com
